April 4, 2017, 06:52 |
Wind effect on water
Danial
Rep Power: 9 |
Can I model (and how) the wind effects on a surface water of an open sedimentation tank? Can I also see the wind effects on the sedimentation process?
April 5, 2017, 18:50 |
Rep Power: 143 |
What effects are you talking about? If you mean the generation of surface waves, then yes, if you use a free surface model you should be able to get surface waves.
April 6, 2017, 04:15 |
Danial
Rep Power: 9 |
thanks for ur response, I am going to see how wind could effect sedimentation in a open channel flow. it means how surface tension made by wind could effect streamlines. and in conclusion how could effect sedimentation.
April 6, 2017, 17:58 |
#4 | |
Rep Power: 143 |
Also: What sedimentation model are you using? I was not aware CFX had a sedimentation model. |
IAPWS water properties + orthotropic thermal conductivity | Chander | CFX | 1 | February 29, 2012 17:26 |
Wind turbine wake effect | caohan | FLUENT | 0 | October 8, 2010 07:54 |
Cooling effect of water flowing on the rooftop | sunnyzai | FLUENT | 0 | February 19, 2010 21:57 |
effect of wind force against structure | zhafir | CFX | 2 | August 23, 2007 18:59 |
swimming pool water surface motion due to wind | J.Kim | FLUENT | 4 | May 5, 2006 10:08 |
