Additional Variable - Diffusive Transport Equation
Old   September 21, 2007, 01:17
Default Additional Variable - Diffusive Transport Equation
RadheShyam Das
I want to solve a transport equation for an additional variable that contains just the transient term and the source term. i.e. no need of diffusion and advection terms. Using the Diffusive transport equation and trying to set Kinematic Diffusivity to zero does not seem to work. Doing so, the solver throws an error and terminates after a few iterations. This is the error during the run.
Fatal bounds error detected
Variable: AggV.Dynamic Diffusivity
where AggV is the additional variable.
Should I set the kinematic diffusivity of the additional variable in the Pre to a sufficiently lower value instead of setting it to zero. Looks like setting it to zero is causing numerical problem
I am solving for a multicomponent gas phase problem where the diffusivity of all components are in the order of 10^-5 m^2/s.
Can anyone suggest a safe value for diffusivity?
Or is there any other way to "trick" CFX into solving just the transient and the source terms?
Thanks,
RadheShyam Das.
Old   September 21, 2007, 11:54
Default Re: Additional Variable - Diffusive Transport Equa
CycLone
Hi RadheShyam,
Based on your description it sounds like you still need the advection term. If that is the case, you can specify it is a "Transport Equation" and set your kinematic diffusivity directly as 1e-5 [m^2/s].
-CycLone
Old   October 18, 2007, 11:24
Default Syntax of "GRANTEMP " variable
Nut
How we insert the "GRANTEMP" variable in the expression?
We found the error; ERROR # 001100279 has occured in subroutine ErrAction. Message: Name_MOD: Error finding variable "GRANTEMP_FL2"
Old   October 18, 2007, 12:35
Default Re: Syntax of "GRANTEMP " variable
opaque
Dear Nut,
It seems you tried to access the granular temperature variable, and the variable has not been defined for your setup. This variable is internal to the ANSYS CFX solver, and it is only defined based on the physical models you have selected.
Without additional information, it is not easy to help.
Opaque
calculation of additional variable in multiple domain cosine CFX 12 April 24, 2016 12:51
How to delete additional variable in CFX Pre Ahlo CFX 0 August 21, 2008 12:34
Poisson equation combined with transport equation Se-Hee CFX 0 December 27, 2007 01:00
Implementing additional equation? Pratap FLUENT 1 December 4, 2004 20:32
additional equation for heat transport Sascha Becker CFX 2 December 20, 1999 02:58
