How to define Inlet air with relative humidity in CFX for turbo machinery? |
January 4, 2023, 21:17 |
MANU P ANAND
Rep Power: 11 |
How can I define relative humidity of air in CFX , I want to calculate the condensation in compressor/ evaporation due to humidity. How to define the air with relative humidity?
How to define the material with air+water content? |
January 5, 2023, 16:37 |
Rep Power: 143 |
If there is no condensation then it is usually modelled as a multicomponent mixture. You model dry air + water vapour. You can then define equations to get the relative humidity from the mass fractions.
If the water condenses and you have mist forming, or water droplets on walls or anything like that it is significantly more complex and you will need the multicomponent mixture and a multiphase model. This type of model will require a skillful CFD operator to complete and is definitely not for beginners.
January 6, 2023, 02:52 |
MANU P ANAND
Rep Power: 11 |
Thank you.Can you share any documents for doing simulation without condensation
question about define speed of rotation and speed of revolution in CFX | weij2018 | CFX | 0 | August 28, 2022 10:10 |
How to define movement/deformation relative to a rigid body motion in Fluent by udf? | eagle_001 | Fluent UDF and Scheme Programming | 6 | May 17, 2022 03:41 |
Air inlet BC for airblast DPM model | FliegenderZirkus | Fluent Multiphase | 3 | June 19, 2020 11:01 |
Relative humidity, how to define? | alpharays | OpenFOAM Pre-Processing | 0 | April 2, 2015 04:23 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
