no convergence at high pressure
Old   October 22, 2007, 04:33
Default no convergence at high pressure
Toralf
I cannot reach the convergence criteria (1E-04) at 60 bar (SST, 2.2 million nodes, v=62 m/s, mesh quality nice). If I choose the pressure 1 bar, then I have a nice convergence after 100 steps. Please have somebody any idea how I can solve the problem? Thank you very much. Toralf
Old   October 22, 2007, 06:59
Default Re: no convergence at high pressure
Does the higher pressure induce higher flow velocities? Is it compressible flow so therefore it chokes? Higher flow velocities or significant compressibility effects often will slow convergence.
Old   October 22, 2007, 07:02
Chirag
Check reference pressure that you are setting. For, good convergence, it should be near to the pressure at which CFD domain is at.
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Simulating a high pressure flow through a valve Kromagnsss FLUENT 8 July 2, 2010 05:20
interFoam: strange pressure with high fluid viscosity? ckroener OpenFOAM 3 April 7, 2010 12:51
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
