angular momentum in swirling flows
Old   October 20, 2007, 11:21
Default angular momentum in swirling flows
Roberto
Hi, I am working with CFD to analyze a swirling burner with a square section combustor. When I calculate the angular and the axial momentum inside the combustor, it decreases the more I check downstream to the burner exit. Do you know what would create a decrease in the angular and axial momentum inside a square section combustor? Should the swirl number variate inside the combustor?
Thank you very much for your help.
Old   October 21, 2007, 22:06
Default Re: angular momentum in swirling flows
Some possible causes: Viscous drag at the walls, turbulence generation, separations causing losses, inaccurate simulation.
Old   October 22, 2007, 04:22
Roberto
Thanks for your answer. Do you know some references about it or how they are modifing the momentum?
Thanks again for your help.
Old   October 22, 2007, 07:05
Look in the literature for swirling flows, such as cyclone separators. For modelling accuracy issues read the documentation or for more detail see Roache's book "Computational Fluid Dynamics".
Angular momentum flux through faceZone askjak OpenFOAM Programming & Development 1 March 5, 2010 14:42
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
angular momentum with swirling flow Roberto FLUENT 0 October 20, 2007 11:18
conservation angular momentum swirling flow Roberto Main CFD Forum 0 October 20, 2007 11:15
Angular momentum conservation? Barry Main CFD Forum 19 April 11, 2002 10:37
