Reynolds number
Old   October 26, 2007, 05:07
Default Reynolds number
Mini
Hello!!
Do you know how I can change the characteristic length used by CFX-solver to calculate the Reynolds number?? If it is possible of course...
Many thanks if you can answer!!
Old   October 27, 2007, 06:27
Default Re: Reynolds number
No, not possible. The thing to do is to manually calculate Re using the parameters important for the flow in post processing, or maybe even set it up as a CEL expression and send it to a monitor point. Then you can monitor it as the solution progresses.
Old   October 29, 2007, 03:51
Mini
Hello!
Ok Thank you for your answer... But I think it is not well, because when I studied a laminar flow in a pipe, with my calculation I had a laminar flow (using the diameter of the pipe), and with the length of CFX solver it was a turbulent flow so I had an error message... That is why I wondered that...
But it doesn't matter anymore
Thanks again!
Old   October 29, 2007, 17:48
This is a warning message only (not an error) and just suggests you to check that your choice of turbulence model to ensure it is OK. If you have checked it then ignore the warning and continue.
This message has been discussed before in the forum, do a search for more information. I think Robin posted a detailed description of how it works a few months back.
Old   October 30, 2007, 13:57
Mini
Ah ok... I will see it.. At the moment, I am working on the dam break problem, I have posted a subject today about it...
Thank you!!
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 02:17
Reynolds Number and Heat transfer Coefficient panos_metal FLUENT 0 January 7, 2011 06:37
Low Reynolds Number k-epsilon formulation CFX 10.0 Chris CFX 4 December 7, 2009 23:51
Reynolds Number Matt CFX 0 February 25, 2009 05:40
