Mixture fraction for combustion problem
Old   October 30, 2007, 20:00
Default Mixture fraction for combustion problem
Jonathan Lemay
Hi everyone
I was wondering if anybody could help me with my problem of getting the mixture fraction available on the result file on my simulation. I am simulating a case in which I am burning Methane and air. I established a material call Methane Air Mixture in which includes CH4, O2 and N2 as pure substance. I simply adjust the mass fraction with the respect of my boundaries conditions for a non premixed burner.
Is there an option I have to select to get the mixture fraction as a variable available in the results file. I tried reactive and non reactive flow but I am only getting the mass fraction of my species and not the overall mass fraction?
Could somebody give me a tip? Best Regard
Old   November 1, 2007, 15:22
Default Re: Mixture fraction for combustion problem
joey2007
Hi, there is more than one way. You can just rerun your case with Burning velocity model. With this approach mixture fraction is a primitive variable. Solver setups it automatically.
Alternatively: you can calculate using CEL in CFX post.
Old   November 4, 2007, 19:55
Jonathan Lemay
Hi Joey
Thanks for your tips I will try this way. What do you mean with the Burning velocity model? Is it a combustion model available in CFX-Pre? Is it a turbulente model?
Finally I found out a way to get what I was looking for. I was running a non-reacting case in which I wanted to estimate the mixing field of CH4 surrounding by air. It work out for the mixture fraction choosing a right combustion model (containing good librairies of flamelet) and setting it to ISOTHERMAL (I chose 300K) in the field of heat transfer. It finally work this way.
Regards
Old   November 5, 2007, 14:57
joey2007
You are right. I am sorry that I missed. You have to use one the combustion models based on the mixture fraction approach. In the case of a diffusion flame this is Laminar Flamelet model. In the (partially) premixed cases this is the Burning velocity model. You can chose both models when you set up a corresponding reaction. (In the library they are termed fll)
Volume fraction of dispersed phase to determine DPM, VOF, Mixture model Mohsin FLUENT 5 March 5, 2018 07:47
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
mass fraction of mixture wlt_1985 FLUENT 2 July 28, 2011 09:39
Mixture fraction with PPDF combustion erikrijk STAR-CD 0 March 18, 2009 08:49
Problem on compacking volume fraction youngan CFX 0 August 16, 2003 02:41
