Drag coefficient & Heat transfer between droplet and mainflow
Hello
I am conducting a steady-state multiphase flow analysis of a compressor, the physical domain contains a rotor stator assembly, air along with droplets of methanol enters the domain from the inlet, the air passing through the blades heat up, the methanol droplets vaporizes absorbing heat from the air in order to keep it cool. I have setup and run the simulation, also reported all the extra variables, now i want to find out the drag forces acting on the particle and the heat transfer between main flow and particles (in my case droplet) but the variables for calculating drag are not accessible in CFD post. Physics: steady state, multiphase, particle transport fluid model, heat transfer "ranz marshal", drag force "schiller naumann", particle collision "CAB", Particle coupling "fully coupled" liquid evaporation model is activated. |
