December 2, 2007, 13:37 |
Area-averaged Nusselt number
Hello together!
I'm investigating a jet impingement cooling arrangement using cfx11.0 and I want to calculate the area averaged Nusselt number of different areas of the target surface. Now my question; how can I divide the target surface (which is one domain in cfx till now) in several areas using cfx post. And how can I calculate the area averaged Nusselt number of these surfaces? Hope you can help me! Thank you |
December 2, 2007, 17:20 |
Re: Area-averaged Nusselt number
The best way is to define them as separate regions in meshing then it is easy to get the results in post-processing. If the target surface has different facets you can still get CFX-post to calculate based on the facets. If you want to sub-divide a larger surface in CFX-Post you can use the bounds option or a user surface with method "from contour" and make the defining contour X/Y/Z functions to define the region you want. It is fiddley but it can be done. Glenn Horrocks |
Display Modes | |
Nusselt number calculation in Fluent | Sharadkumar Yeri | FLUENT | 52 | May 29, 2019 07:29 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 13:55 |
what is Surface Nusselt Number | jlx | Main CFD Forum | 0 | January 13, 2011 23:26 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 11:37 |
Nusselt number | tod | Phoenics | 0 | October 18, 2002 10:56 |
