running CFX-RIF: error window
Hi everyone
Ok I finally got an access to CFX-RIF with my local distributor. I installed the program without any problem an I can open it from my CFXlauch-bar. My problem is when I lunch a run in the program. I have an error windows saying: Could't execute "c:\Program": no such file or directory. Is anyone experienced this problem? Is there a trick with the working directory? Thanks in advance. |
Re: running CFX-RIF: error window
The problem is where you have installed the application. I suggest you to install it on C: drive root, for example:
C:\CFXrif Hope this helps, |
Hi Ribeiro
I did what you said (installing in on root c: and another error window opened RIF:child process exited abnormally got an idea? Regards |
possibly the licence
Hello everyone
Well it is harder then I tought. I finally got the good license from my provider, but I am still with the same problem. Did somebody that already suceed installing and running CFX-RIF could give me a hint. Thanks a lot in advance |
is it a test licence? may be limited
Dear user
Someone knows what is the license software tool that must be used for CFX-RIF. Currently for normal CFX their is FlexIM license manager who deal with my CFX-license. What I did was to add my CFX-RIF license line to my current CFX license file. Unfortunalty it has not work. Somebody knows CFX-RIF work with the license. Do I need another licensing software then FlexIm license manager Thanks in advance |
Test licence may work with the old CFX licence tools and not with the actual ANSYS licence manager
Hi Joey
Do you have this old CFX-license tools? Maybe I could download it. I guess it is not too big if it is old? Regards |
Hi Joey
Do you have this old CFX-license tools? Maybe I could download it. I guess it is not too big if it is old? Best Regards |
You may some old distributions (5.7 or so) or ask your local cfx representative. I do not suppose that you can download it.
