December 3, 2007, 19:34 |
fortran dll
hi!
ive got a quick question. i want to include a fortran code into cfx. for this i want to work through the tutorial which is written in xmod11.pdf but when i want to create my dll file, i have a problem like this: F:\study\project\progg\ansystest>cfx5mkext userpart.F df -MD -fpp:-m -include:"c:\programme\ansys inc\cfx\cfx-10.0\include" -object:wi nnt\\userpart.o -c userpart.F df: invalid option -- M Try `df --help' for more information. An error has occurred in cfx5mkext: df exited with return code 1. where is the problem? i can compile my fortran code in the command line. it is a compiler which is included in cygwin. so the compiler is there. iam using cygwin in winnt to compile my fortran code my path variable include this lines: C:\cygwin\bin;c:\programme\ansys inc\cfx\cfx-10.0\bin do i need special compilers? if so, which ones? thanks for help! |
December 4, 2007, 07:58 |
Re: fortran dll
i think iam a little bit more closer to what i want to do.
i found out that all the processes with cfx5mkext run with its properties in the ccl file. iam using the g77 compiler (under cygwin) in winnt. what settings do i need to do in this file? these are the standard settings for linux OS: linux cc = gcc fc = pgf90|g77 ld = ld ext build cflags = -fpic ext link ldflags = -shared FORTRAN: pgf90 # maybe we shouldn't use -Msecond_underscore? ext build fflags = -fpic -Msecond_underscore -g77libs ext link ldflags = -shared -g77libs END ATTRS: double cppflags = -DDOUBLE_PRECISION FORTRAN: pgf90 ext build fflags = -fpic -Msecond_underscore -g77libs -i4 -r8 END FORTRAN: g77 error message = Double Precision builds are only supported \ using the Portland Group compiler under Linux. If you have this compiler \ installed already, ensure that it is in your PATH. END END CHIPSET: ia64 cc = ecc fc = efc ext build cflags = -fpic #ext build fflags = -fpic -cm END END and these are the values for winnt. OS: winnt cc = cl fc = df! ld = link cxx = cl ext build cflags = -MD ext link ldflags = -threads ext link lib5files = solver-pvm.lib cppincflag f = -include: cppflags f = -fpp:-m fc outopt obj = -object: fc outopt exec = -dll: cc outopt obj = -Fo ext lib suffix = dll ext lib pattern = %s.dll ATTRS: double cppflags = -DDOUBLE_PRECISION ext build fflags = -integer_size:32 -real_size:64 -MD ext link lib5files = solver-pvm.lib END END i tried to play around with some lines, but i get error messages instead a dl file. anybody knows this problem? |
October 19, 2010, 10:01 |
Gabriele
I have a similar problem.
OS: windows XP 64-bit CFX version: 12.1 Fortran compiler: PGI Visulal Fortran 2008 I know I must set up the cfx5mkext.ccl in order to link properly CFX to the Fortran compiler. Currently the cfx5mkext.ccl is: [...] OS: winnt amd64 cc = cl fc = pgf77|pgf90|pgf95 ld = link cxx = cl ext build cflags = -MD ext build fflags = -Qvec- -iface:cvf -MD ext link ldflags = -threads -dll ext link lib5files = solver-mpich2.lib cppincflag f = -include: cppflags f = -fpp fc outopt obj = -object: fc outopt exec = -exe: cc outopt obj = -Fo ext lib suffix = dll ext lib pattern = %s.dll ATTRS: double cppflags = -DDOUBLE_PRECISION ext build fflags = -Qvec- -iface:cvf -integer_size:32 -real_size:64 -MD ext link lib5files = solver-mpich2.lib END END When I run my routine from CFX command line I obtain: C:\Archivio\arccfx\FIVE_STEPS>cfx5mkext runoa.f C:\Program Files\PGI\win64\10.8\bin\pgf77 -Qvec- -iface:cvf -MD -object:winnt-amd64\\runoa.o -c runoa.f pgf77-Error-Unknown switch: -Qvec- pgf77-Error-Unknown switch: -iface:cvf pgf77-Error-Unknown switch: -MD An error has occurred in cfx5mkext: C:\Program Files\PGI\win64\10.8\bin\pgf77 exited with return code 1. |
October 19, 2010, 15:26 |
Check the help. I guess for windows intel is supported and not portland group. To be sure check it. May be I remember not correctly.
Fortran Compiler-CFX12.1 | Araz | CFX | 13 | March 27, 2017 06:37 |
Importing external DLL to Ansys CFX using user Fortran | snpradeep | CFX | 2 | May 16, 2014 04:52 |
CFX11.0 cannot find dll in User Fortran | brunoc | CFX | 0 | April 4, 2007 11:42 |
CFX 10 User Routine NOT in Fortran | Andre | CFX | 14 | August 9, 2006 00:03 |
visual fortran | Monica | Main CFD Forum | 1 | August 28, 2004 21:45 |
