Negative Volume Error
Old   December 10, 2007, 12:17
Default Negative Volume Error
Srinivethan
i am doin an analysis of different aerofoils but am not able to procedd coz watever meshing i do i keep gettin the negative element error. i am using icem cfd wat correction should i do to rectify this?? help Plz!!
Srinivethan
Old   December 10, 2007, 16:15
Default Re: Negative Volume Error
This error is common in moving mesh - I assume you do not have any moving mesh. If you have a static mesh then you either have a very poor mesh where some elements have been turned inside out (sometimes too much smoothing can do this) or the normal vectors are wrong (this is easy fixed in ICEM).
Old   December 11, 2007, 10:56
Srinivethan
thanks but my mesh quality is fine i checked it out. and i am doin a 2d analysis as in when i am exporting from icem i am giving the z scale as 0. so basically i get a 2d structure in cfx will that be a problem???
Old   December 11, 2007, 16:27
No that will not work and that is where the error is coming from. You need to have a finite thickness in the z direction. Also read the FAQ: http://www.cfd-online.com/Wiki/Ansys...tion_in_CFX.3F
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
