Exporting results from CFX to ANSYS ??
Old   December 19, 2007, 08:26
Default Exporting results from CFX to ANSYS ??
sohail ahmed
Dear friends,
I am trying to run a 2-way coupled Fluid structure interaction problem in ANSYS. In this case, as you know, both ANSYS and CFX solver starts same time. I wanted to transfer pressure, temperature and wall heat transfer coefficients from CFX to ANSYS( in a transient mode). But when I introduce the interface between fluid and structure for transformation of results in this 2way coupled simulation e.g. by defining a wall between fluid and structure and saying:
Mesh Motion-
Option: ANSYS Multifield,
Receive from ANSYS: total mesh displacement,
ANSYS Interface: FSIN_1,
Send to ANSYS: Total force
and
Heat transfer-
Receive from ANSYS: wall heat flow,
Send to ANSYS: Temperature,
It gives me following ERROR:
""Export results are unavailable as no suitable boundaries exist for use as export surfaces. Mesh motion on a boundary invalids its use as an export surface.""
Thanks Sohail Germany
Old   December 20, 2007, 01:10
Default Re: Exporting results from CFX to ANSYS ??
Chirag Jayswal
Check if solid-fluid interface surfaces are matching exactly. Any difference between them can cause this error.
Best luck,
Chirag
Compressible Flow in Ansys CFX bcheruk CFX 15 July 6, 2017 06:30
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 09:16
Ansys 13 CFX problem on LInux Opensuse 11.4 serendipity CFX 10 August 7, 2012 03:24
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 18:47
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 04:47
