CEL expression in CFD-Post multiple volume
Hi everyone,
Now I'm struggling to define the volumeAve(Temperature)@<location>. If I want to know the temperature of two volumes, how can I write in the 'location' area? For example, Component 1: Case 1 Component 2: Cell 1 And at the end, I want to see the data of each time step after heat transfer between two components. I want to define those two volumes into the function. |
I assume you are in CFX-Pre, correct?
If so, you can create a Composite Region. Go Insert/Region/Composite Region Just filter by 3D dimensionality, and create a union between those volumes. You can then use volumeAve(Variable)@MyCompositeVolume |
..... or you can do a volume average of those two volumes:
TotalVolAve = (volumeAve(T)@Location 1*volume()@Location 1 + volumeAve(T)@Location 2*volume()@Location 2)/(volume()@Location 1 + volume()@Location 2) |
Thank you for your reply!!
I will try it. It really helpful :) |
Convection coefficient
Thank you for your Answer!!
Please start a new thread for a new question. Do not hijack existing unrelated threads.
Also, this question appears to be about Fluent. This is the CFX forum. Please ask this question on the Fluent forum. |
