how to make turbine blade in Ansys Blademodeler |
January 18, 2008, 10:36 |
Hi, I have three radial sections of a turbine blade (at hub, mean and tip). How can i make full 3D blade out if it in Blademodeler. Kindly also tell if i mesh the turbine geometry in TurboGrid, can i export it to Fluent for CFD analysis. Many Thanks,
January 18, 2008, 12:39 |
Re: how to make turbine blade in Ansys Blademodele
Hi Usman
Regarding your second question you should be able to do that! I have never done it though. Regards Usman |
January 22, 2008, 04:17 |
Hi Usman!
There are some examples of bladegen files stored in your root directory(else search for .bgd files)which can give you some idea about how to make a turbine blade. |
January 29, 2008, 04:53 |
please help in simulating a wind turbine blade in 6 DOF ????.... | usman naseer | Main CFD Forum | 2 | March 10, 2016 02:53 |
conjugate heat transfer of a turbine blade | Steven-GY | FLUENT | 1 | February 23, 2013 14:31 |
[ANSYS Meshing] Mesh elements inside turbine blade | eoinsturbine | ANSYS Meshing & Geometry | 2 | May 15, 2011 11:44 |
[Other] ANSYS CFX-Meshing problem of a wind turbine blade | Zoe | ANSYS Meshing & Geometry | 1 | July 14, 2010 02:02 |
Wind Turbine Blade Geometry | SeanieB | Main CFD Forum | 0 | November 27, 2009 10:18 |
