Joey Improta
Rep Power: 2 ![]() |
Hello all,
I need help plotting the drag coefficient on a transient flow past a flat plate. I have ran the simulation and I've tried to write expressions, but I can't seem to figure out how to plot the drag coefficient in the X direction. Attachment 96247 Attachment 96248 |
Rep Power: 141 ![]() ![]() ![]() ![]() |
There are many ways of doing this, one which comes to mind is:
* Define a new variable (The "x" button on the toolbar) * Define the variable to have your expression * It is now a simulation variable available for post processing, like all the others.
Joey Improta
Do I define the variable in the preprocessor or the post processor?
You can do it in either. If you do it in the preprocessor you will need to solve again for it to be calculated. If you do it in the post processor it will be available straight away.
Joey Improta
Oh okay I see, well I did that and the graph I get is a straight line instead of the curve im expecting. I may be looking at the problem the complete wrong way, the professor asked us to do it in Fluent but I have already been working in CFX and this seems valuable for me to learn how to do in CFX instead of just using another piece of software for one problem,
So you need to work out whether the incorrect response is because you are not doing the post processing properly or because the simulation results are not accurate.
If you want us to help you there post some images of what you are getting. Also some images of your mesh and some images of the flow.
Display Modes | |
Drag force and drag coefficient | abose06 | ANSYS | 1 | December 11, 2020 00:55 |
Looking for a quick help with Drag Coefficient using ANSYS Fluent | kesilowes | ANSYS | 1 | October 1, 2020 11:30 |
Drag Coefficient on flat plate normal to flow | Bin | STAR-CCM+ | 19 | June 26, 2017 12:03 |
Drag on a flat plate | ac_ankit | Main CFD Forum | 0 | October 15, 2011 07:41 |
Drag coefficient Oscillating plate | Anant | Main CFD Forum | 0 | September 6, 2001 11:31 |
