Maximum Mesh Expansion Factor
Old   February 8, 2008, 23:38
Default Maximum Mesh Expansion Factor
KK
Hi, The solver output gives the following message under 'Mesh Statistics'. ************************************************** *** Minimum Orthogonality Angle [degrees] 30.0 ok Maximum Aspect Ratio = 20.1 OK
Maximum Mesh Expansion Factor = 118.8 ! ************************************************** ******
What does the sign of '!' mean besides the 'Maximum Mesh Expansion Factor'? Please help.
Thanks, KK
Old   February 8, 2008, 23:47
Default Some more information to my problem
KK
Just one more comment... I checked Edge length ratio and it was less than 10. And I use inflation and the first layer thickness is set to be 1 mm while the maximum element size is 2.5 mm. At a few places I have used spacing to start with 1 mm.
Old   February 10, 2008, 16:31
Default Re: Some more information to my problem
The ! means that the value is high and has a significant chance of causing a convergence or accuracy problem. If possible you should try to improve the mesh to reduce the number.
It is normally OK to have quite high aspect ratio elements in the boundary layer against a surface, providing they are prism or hexa elements.
Old   February 11, 2008, 05:12
Subha
Hai KK,
The Maximimum Mesh Expansion Factor just reflects that in your mesh the cells does not expand in an orderly manner. If you are working with ICEM, then check for the elements with higher Volume Change value and try to bring their value down, near to 20. This could be easily done by just changing the edge length raio.
Pre-Mesh params -> Meshing parameters -> Edge params
Regards,
Subha.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
Maximum of Mesh Size R.Abd ANSYS Meshing & Geometry 1 October 3, 2010 14:16
early stall, poor convergence, and mesh quality everest CFX 2 May 12, 2010 16:27
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
