How to monitor variable values of point at t=0 sec
Old   February 12, 2008, 22:48
Default How to monitor variable values of point at t=0 sec
yunhee
I wonder how I can monitor values of user points at t=0 sec in cfx-solver. Graph shows the values from t=1 sec instead of t=0 sec. If somebody know it, please let me know it. Thank you.
Old   February 13, 2008, 05:15
Default Re: How to monitor variable values of point at t=0
Subha
Hai Yunhee,
The values at t=0 are the initial values you set or those calculated by the solver(if automatic intial values are chosen).
Regards,
Subha.
Old   February 13, 2008, 10:02
Carlos
Heloo,
You can save a backup at t=0 setting the expert parameter "backup file at zero=t"
Old   February 13, 2008, 12:45
yunhee
Thank you, Subha and Carlos. According to Carlos advice, I could save a backtup at t=0. By the way, I want to plot the values (e.g., force) of user defined points at t=0 in monitoring window of cfx-solver. Then I can save the values at t=0 with csv file using the export plot data function. Although I set the expert parameter (backupt fiel at zero=t), the plot starts from t=1 still. So, I cannot do what I want explained above. If you don't mind, could you please give any idea to solve this problem? Thanks a lot.
Monitor Point Values Tristan CFX 2 October 28, 2008 14:01
Monitor point values in a steady state simulation Kushagra CFX 2 July 13, 2008 20:03
output point values in CFX4 Dougal McQueen CFX 1 February 13, 2004 23:55
Output from the Monitor point command swapnil CFX 0 November 20, 2002 22:08
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
