How to monitor variable values of point at t=0 sec |
February 12, 2008, 22:48 |
I wonder how I can monitor values of user points at t=0 sec in cfx-solver. Graph shows the values from t=1 sec instead of t=0 sec. If somebody know it, please let me know it. Thank you.
February 13, 2008, 05:15 |
Re: How to monitor variable values of point at t=0
Hai Yunhee,
The values at t=0 are the initial values you set or those calculated by the solver(if automatic intial values are chosen). Regards, Subha. |
February 13, 2008, 10:02 |
Heloo,
You can save a backup at t=0 setting the expert parameter "backup file at zero=t" |
February 13, 2008, 12:45 |
Thank you, Subha and Carlos. According to Carlos advice, I could save a backtup at t=0. By the way, I want to plot the values (e.g., force) of user defined points at t=0 in monitoring window of cfx-solver. Then I can save the values at t=0 with csv file using the export plot data function. Although I set the expert parameter (backupt fiel at zero=t), the plot starts from t=1 still. So, I cannot do what I want explained above. If you don't mind, could you please give any idea to solve this problem? Thanks a lot.
Monitor Point Values | Tristan | CFX | 2 | October 28, 2008 14:01 |
Monitor point values in a steady state simulation | Kushagra | CFX | 2 | July 13, 2008 20:03 |
output point values in CFX4 | Dougal McQueen | CFX | 1 | February 13, 2004 23:55 |
Output from the Monitor point command | swapnil | CFX | 0 | November 20, 2002 22:08 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
