difference between mass flow rate in CFX post and solver |
August 29, 2017, 16:33 |
yaseen
Rep Power: 10 |
hellow everyone
as shown in the attached figure there is difference between outlet mass flow rate in CFX post and in solver after finishing, which one is correct? https://www.cfd-online.com/Forums/at...1&d=1504038740 https://www.cfd-online.com/Forums/at...1&d=1504038763 |
August 29, 2017, 19:10 |
Rep Power: 143 |
The solver calculates using the integration points. By default the results file has the results simplified back to just the nodes, so the post processor calculates using the nodal values. This will lead to a small difference between values calculated in the solver and the post processor. The difference should get smaller with a finer mesh. The "correct" value is the one calculated by the solver.
August 30, 2017, 09:28 |
Rep Power: 32 |
I do not think you are comparing the same mass flows.
In the solver output, you are comparing the mass flow of water (Mass-Water) while in CFD-Post you are computing the total mass flow. A more appropriate comparison would be to add the following to the CFX-Solver monitor output: Water.massFlow()@outlet massFlow()@outlet <whichever other phase there is>.massFlow()@outlet In CFD-Post, you should be able to compute the water mass flow by selecting the appropriate "Fluid" in the widget below. Also, you can select "Show equivalent expression" to see what expression is being computed. |
August 30, 2017, 13:37 |
#4 | |
yaseen
Rep Power: 10 |
August 30, 2017, 14:06 |
Rep Power: 32 |
One of them will, the other two will not.
Which one are you interested in verifying? |
August 31, 2017, 06:11 |
yaseen
Rep Power: 10 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 18:11 |
Mass flow rate of phase in post | mat_cfd | CFX | 0 | September 3, 2013 07:55 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 10:09 |
viewing cfx post while working on cfx solver manager | HMR | CFX | 5 | March 9, 2011 22:33 |
