Periodic flow
Hi, I have an unsteady flow. At the inlet , velcoity U=0.2+0.3*sin(100*t) At outlet : opening type
At some times my inlet would be outlet. How should I choose Boundary condition in this case? Thanks, ---Selim |
Re: Periodic flow
If you mean that sometimes the flow goes into the domain and sometimes it goes out - that is fine, an inlet with a prescribed velocity should work here. Glenn Horrocks |
Re: Periodic flow
you can execute it by using inlet boundary, because the 'inlet boundary' does not only means that the fluid flow into the calculating region.
