Problem in Axial turbine stage NonEquilibrium Calculation
Old   April 13, 2016, 00:38
Default Problem in Axial turbine stage NonEquilibrium Calculation
Bharath kumar
bharath is on a distinguished road
Hi to all
I am doing simulation for Axial turbine (Steam turbine) Last Stage Blade Non Equilibrium calculation using IAPWS table.
1)For Droplet Condensation, I used MUSIG approach for different size particle diameters (1µ to 20 µ). While doing post processing, I found that steam(liquid) temperature (Tl) is more than steam (Vapor) temperature (Tv). Tl > Tv
2) However when using small droplets model Steam (liquid) temperature is less than Steam (Vapor) temperature. Tl < Tv and I think this is right.
Why Tl > Tv in MUSIG approach? Could any body help me regarding this issue.
Thanks in advance
bharath is offline   Reply With Quote
Old   April 19, 2016, 00:15
Bharath kumar
After further study I found the reason for this.
At first in both models Tl>Tv.(i.e) steam (liquid) temperature is greater than Steam (gas) temperature. Previously, I noted it wrong.
Steam (gas) is in super cooled state (otherwise metastable region) Tl is greater than the Tv. This is possible in meta stable regions and nucleation barrier is stopping steam (gas) to convert into liquid.
Thank you all.
Problem in Torque calculation Achilleas CFX 21 July 25, 2018 09:14
problem in the calculation of pressure drop for an axial turbine aja1345 FLUENT 0 January 1, 2016 14:07
Problem in Torque calculation Achilleas ANSYS 0 October 1, 2015 08:56
Problem with inv_ONERAM6 parallel calculation burchio_cfd SU2 6 December 2, 2013 14:16
Pressure calculation for internal problem using 3D panel method Vitek Main CFD Forum 1 November 10, 2013 11:15
