Loading expressions into fortran routine
Old   February 26, 2008, 04:47
Default Loading expressions into fortran routine
ats
Is there a way for me to load expressions defined in CFX-Pre into my fortran routine for use in a transient run.
eg. if I have an expression FX = force_x()@Structure - can this be accessed in my fotran routine? (I know there are other ways to achieve the resulting force on a boundary, but the question here is how to load an expression into my fortran routine).
- ats
Old   February 26, 2008, 09:20
Default Re: Loading expressions into fortran routine
opaque
Dear ats,
That cannot be done directly. There several alternatives
Alternative 1: done by using USER_GET_GVAR.
Please take a look at the documentation. For an example,
CALL USER_GET_GVAR (' ','Structure','force_x',
& CRESLT,REXPRESSION,
& CZ,DZ,IZ,LZ,RZ)
CALL USER_PRINT_REAL('area_x()@Inlet',REXPRESSION)
Alternative 2: Create an Additional Variable, set it as an Algebraic Equation, and make it equal to force_x()@Structure. Then, pass it as argument list to your USER CEL function (fortran routine).
Hope this helps,
Opaque
Old   February 26, 2008, 09:29
ats
Thank you for the reply.
Alternative 1 is not a possibility, simply because in this case I need area integrated values that aren't integrated over the entire boundary.
Alternative 2 could work I suppose, but will it not take an entire column in ARGS of size (NLOC,1) ?
- ats
Old   February 26, 2008, 09:54
ats
I tried creating an additional variable:
FX: Variable type - Specific Units - [N] Tensor Type - Scalar
and in Domain/Fluid Models I set it to "Algebraic Equation" with the expression "force_x()@Structure".
When I use this as argument for my CEL function I get the following msg in the .out file:
ERROR #001100279 has occurred in subroutine ErrAction. Message: The fluid/solid qualifier for the additional variable FX cannot be determined. Please ensure that the name is prefixed with the fluid or solid name.
Any pointers?
- ats
Old   February 26, 2008, 11:01
opaque
Dear ats,
I think the message is very clear. The solver is expecting (not sure why) that you prefix the variable FX by the fluid/solid using it.
Try doing so, as in MyFluid.force_x()@Structure, where MyFluid is the name of the fluid you are using.
Also, the single value will use a full array (1:NLOC) since the mechanism to transfer data does not differentiate a single value from a multivalue arg list. It only knows is a variable.
Opaque
Old   February 26, 2008, 19:08
Anders
Ok thank you, I will try that
- ats
Old   February 27, 2008, 04:35
ats
I have tried changing my additional variable to 'Air at 25 C.force_x()@Structure', which does not cause for any warnings in PRE. However when I run the solver, I get the following two errors:
ERROR #001100279 has occurred in subroutine ErrAction Message: An error: Illegal Vector Component for callback function force_x()@Structure
Details of error:- ---------------- Error detected by routine MAKDAT CDANAM = LVAR CDTYPE = INTR ISIZE = 90 CRESLT = OLD
Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/VARIABLES
I really am desperate to figure this out, as it is halting all progress.
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 18:37
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
FORTRAN Routine - variable passing Malcolm CFX 1 August 11, 2005 18:51
