August 2, 2010, 13:13 |
Heat transfer in the reactor pressure vessel
M. A.
Rep Power: 15 |
Hi friends,
I'm simulating a RPV (reactor pressure vessel). When passing the coolant through the fuel assemblies, the coolant takes the heat from the fuel assemblies. The boundary condition I define for fuel assemblies in CFX-pre is the heat flux. Even though I insert the maximum heat flux for the fuel assemblies, the coolant warms just a few degrees, in the case that it has to be heated about 32 degrees. I don't know what's the matter??? Can any friend help me about this problem??? I urgently need your help!!! |
August 2, 2010, 18:52 |
Rep Power: 143 |
Obviously your heat transfer model is very inaccurate. Assuming you have the physics of the simulation set up correctly, have you checked your mesh resolution? Convergence? Time step size (if transient)? Y+?
August 3, 2010, 04:04 |
M. A.
Rep Power: 15 |
I have changed the time step many times, but the results were the same.
I also changed the number of mesh elements without gaining a good result. I haven't worked on the mesh resolution a lot. I think I have to work on it more. Thanks for your help ghorrocks. |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
CFX Heat Transfer | RJamison | CFX | 0 | July 24, 2008 12:11 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
