How do I model a "corrugate Pipe"?
Old   March 21, 2008, 01:11
Default How do I model a "corrugate Pipe"?
Young
I always appreciate your attentions.
I would like to model a corrugate pipe.
when I make a sectional surface and revolve it, it is not able to make a "solid Body".
Therefore, I cannot make a domain interface with the other solid body.
when I make a convential tube model, it is possible to make interface using "Encloser" tool.
Here my question.
when I make a surface body with "revolve" command, how do I change it a "Solid" body.
Actually, the sectional shape of my pipe is as follows;
∨∨∨∨∨∨∨∨∨∨∨∨&o r;
Thanks
Old   March 21, 2008, 02:19
Default Re: How do I model a "corrugate Pipe"?
Dre
When you make a revolved feature, if it isn't completly enclosed, it will make a surface. If the section is clompletly closed, then it will make a solid volume.
First check to see if there isn't a small line somewhere that isn't fully connected.
Old   March 24, 2008, 23:45
Young
I really appreciate you, Dre.
Let me ask one more.
As you know, it is a straight tube when I use revolve command.
Would you give me an idea for bending or sweeping the straight tube?
Thanks Dre.
Old   March 25, 2008, 00:25
Dre
Sorry I can't help you there. I don't know how to do this in Design Modeler.
However, couldn't you just model a normal smooth pipe, then set an appropriate surface roughness in CFX?
Mixture model - pipe flow Aly FLUENT 10 June 21, 2010 13:50
fsi model of water flow in a pipe alinik CFX 11 November 5, 2009 11:29
[blockMesh] 3d mesh for a pipe tsjb00 OpenFOAM Meshing & Mesh Conversion 2 January 30, 2009 04:40
Non newtonian power law model in pipe annulus Poly FLUENT 0 March 24, 2005 15:12
