K epsilon Yplus
Old   April 2, 2008, 15:19
Default K epsilon Yplus
nick
Hi
I'm using the K epsilon model and generally have Yplus values between 70 and 30. However there is a region where it drops to around 6 (due to a very low wall shear i think). Is this generally an issue that could corrupt my results in other regions of the flow?
Thanks
Old   April 2, 2008, 16:03
Default Re: K epsilon Yplus
hp_c360
Please have a look at page 96f of the "CFX Reference Guide". The different approaches regarding wall treatment are explained there. If your solution is corrupted by a low y_plus-value depends mostly on the influence the wall has on your flow. If its a free flow with shear layers you should be "safe". If it is a throughflow-problem, things are different. Maybe you would like to use another turbulence model, either.
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM 0 March 10, 2011 09:58
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 04:43
