Non-premixed diesel combustion-which code to use?
Old   March 31, 2008, 16:13
Default Non-premixed diesel combustion-which code to use?
joey
I want to model a gas turbine combustor. Air enters the domain and passes a swirler. Downstream of the swirler diesel fuel is injected by a spray nozzle. My question: What Code is preferably used to model this problem? (I have already modelled some complex flows in Star-CD and Fluent 5/6. But they were all non-reacting, single phase flows.) Could anybody please comment on this? Thanks a lot!
Old   April 1, 2008, 04:47
Default Re: Non-premixed diesel combustion-which code to u
Dr. Flow Squad
AVL FIRE? http://www.avl.com/wo/webobsession.s...jExNzQ_3D.html
Old   April 1, 2008, 05:39
joey
Thanks for your advice! But the choices are limited to Fluent, CFX or Star-CD. There are no other licenses available...
Old   April 1, 2008, 17:34
Have a look at the CFX-RIF package as well. That may be useful. All the leading CFD codes will be able to model the flow. As for which is best - that is harder to answer. You will have to trial them and find out. Also talk to support as they know the software the best and can give you a head start.
Of course, if you are on an academic (or pirated!) license then your access to support is limited or zero. You get what you pay for!
Old   April 2, 2008, 05:52
joey
Thanks for the input! I think I'll stick to Fluent, because I know the interface. The PDF-Approach seems the way to go. I just asked for advice because I'm totally new to combustion modelling - so why not get used to another code? The licenses are academic indeed...
Old   April 2, 2008, 17:24
As I previously mentioned I think you should also have a look at CFX-RIF. This package will allow you to generate flamelet libraries for the CFX solver to use in the combustion model. It can handle just about any fuel/oxidiser mixture and therefore more accurately capture the chemistry of the combustion. Whether this is more appropriate than a PDF approach depends on your application but I strongly suggest you have a look at it and be aware of what it can do.
premixed combustion using Zimout model wanghuiru FLUENT 0 July 8, 2010 23:36
Help about premixed combustion with BVM model Nena CFX 1 September 8, 2007 10:15
diesel engine spray and combustion usker Siemens 6 April 24, 2006 22:36
diesel combustion Marco FLUENT 0 September 14, 2005 08:27
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
