Partioner error
Dear all, I've made two meshes in Icem CFD Hexa. I've merged and export it to CFX. When I try to run it the message is as follow:
ERROR 444000026 has ocurred in subroutine PartMain_Info The follow domain was not succesfully partioned: Domain 1. No overlap vertices exist in this domain and this is not supported by the flow solver yet. Change to a different number of partitions or use a different partiotioning method. This error can by bypassed using expert parameter accept non overlap partitions = T Note that this option is currently a beta feature In my CFX I don't have this option, some Idea ??? Thanks J. |
Re: Partioner error
Julian
Try the CFX's advice and write in the CCL. This's not avaliable in GUI, you should use a text editor. Write this: FLOW: EXPERT PARAMETERS: accept non overlap partitions = t END END You should check mesh on ICEM to verify non-overlaping faces and vertices. Regards Kostetzer |
