April 11, 2008, 00:59 |
about the set up of "oil" material
I'm making a simulation of three phase flow --water,gas and oil.The composition of oil is so complex that I found no way to make it up!Is there anyone who use it can help me ? Please reply!
April 11, 2008, 03:56 |
Re: about the set up of "oil" material
If it's just a 3 phase, incompressible, isothermal calculation without chemical reactions, you can specify for the oil the viscosity and density. That is a fairly common approach. Viscosity and density are normally known for any kind of oil.
Bart |
April 12, 2008, 08:59 |
Good advice! thanks very much,Bart
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
how to set a thin layer of different material over a domain? | jehan | CFX | 2 | June 8, 2010 03:20 |
How to set layer composite material in Ansys workbench | timyew | ANSYS | 0 | May 16, 2010 13:53 |
Installation problems | indy | OpenFOAM Installation | 7 | April 3, 2009 09:40 |
Ibm java gcc | rrr | OpenFOAM Installation | 2 | December 30, 2005 04:18 |
