Import geometry
Old   April 14, 2008, 06:07
Default Import geometry
Cristiano
I have got a geometry combustors realized in Sildworks. Is it importable in CFX without problem (about file extension)?
Thank you everyone
Old   April 14, 2008, 14:44
Default Re: Import geometry
Rodrigo Basniak
Cristiano,
You can export it to Ansys Workbench and mesh it with CFX-Mesh. After that you just open the mesh on CFX-PRE.
To export to Ansys WB, save it as IGES on Solidworks. You also com link it directly to SW model. You sould have an Ansys menu on Solidworks where you can do that.
I hope it helps.
Rodrigo Basniak
Old   April 14, 2008, 21:44
Rogerio Fernandes Brito
yoU must use Part1.SLDPRT file to open on Design Modeler. Forget this kind of iges. file. I had problems with iges. files! If you wanna simulate different parts of you complete body (=assembly), you have not to choose the "merge" option on Solid Works, when you are creating (extruding) the second part of your assembly on SW.
Import geometry from CAD Giuseppe (Giuseppe) OpenFOAM Pre-Processing 34 December 14, 2017 16:24
[ICEM] Import geometry from solidworks holyo ANSYS Meshing & Geometry 11 April 16, 2014 11:47
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[GAMBIT] import terrain geometry cfdworker ANSYS Meshing & Geometry 2 May 24, 2009 21:40
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
