volume fraction,mass fraction,bulk mass flow
Old   April 25, 2008, 09:51
Default volume fraction,mass fraction,bulk mass flow
nick
"Hi! all friend I have a confusing problem when I try to set the value of "volume fraction" in the inlet condition fluid values tab for a gas-liquid two phase problem. If I give the value of volume fraction of different phase, what values should I give to the "Normal speed" of the two flow??are these values also apparent velocity or I should give a same velocity?? this problem confused me and I always give Mass flow rate for every flow.
by the way, when I select "Bulk Mass flow rate" in Boundary Details tab of inlet, I find the volume fraction in the fluid values tab means Mass fraction!(you can find this conclusion from the result file using CFX-POST).Is it true?? " Two questions above are cited from former messages which are just good for me.thanks for your reply!
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Mass Flow Rate Error jallison FLUENT 1 May 16, 2011 16:22
Mass Flow Rate student87 CFX 4 January 2, 2010 04:45
mass flow in is not equal to mass flow out skarp CFX 8 August 19, 2007 01:55
