questions in initial conditions and inlet boundary
Old   April 17, 2008, 22:28
Default questions in initial conditions and inlet boundary
nick
hi,I'm similutaing a two phase flow.I set the velocity and the volume fraction at the inlet.The same terms could also be specified in domain>initialization.I'm a little confused. what's their relation and difference ?The respective value should be the same or different? thanks
Old   April 18, 2008, 05:50
Default Re: questions in initial conditions and inlet boun
cfd-student
I would say dont worry about domain initilistaion. Just set up your global initialisation values.
Old   April 19, 2008, 09:26
nick
thanks,I get somthing . the initialisation value should be the first iterative value .It could be interiorly guessed by "automatic". I consult some tutorials ,they are ususlly the same.
(this arise from my simulation convergence problem.I guess it has someting to do with the initial conditions.Now I find the reason that the boundary conditions are specified improperly.It works now.)
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
