time to reach steady state with transient simulati |
April 21, 2008, 07:53 |
Hi Glenn and Robin,
Can we estimate the time for reaching steady state with transient simulation? I plot the streamline starting from the inlet and with 'symbols' at different times. Whether the 'time' of the symbol which is at the outlet of the domain the residence time (i.e. the time required for the information at the inlet to propagate to the outlet)? Can this residence time be the time to reach steady state even when i use multigrid solver? thanking you |
April 21, 2008, 10:17 |
Re: time to reach steady state with transient simu
if it is possible, why do not you try a steady state simulation? After that, make a transient simulation. For it, make a point of monitoring of the temperature for example and you will see the behaviour of this variable.
April 21, 2008, 10:18 |
How about it?
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
can t reach steady state chtMultiregionFaom | mabinty | OpenFOAM Running, Solving & CFD | 12 | July 30, 2009 04:46 |
false time step implementation for steady state | Kushagra | CFX | 1 | June 22, 2008 19:06 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
