High resolution scheme???
Old   April 22, 2008, 09:15
Default High resolution scheme???
vijay
Dear friends, I am trying to simulate flow over a blunt body (hypersonic flow problem), flow over an airfoil (supersonic flow problem) and flow over an automobile (subsonic case)... I am using UPWIND scheme for all the three problems... IS THAT OK?? In what type of problems we can use HIGH RESOLUTION scheme???
what is that advection scheme?? I have not heard of that before..
Thanks in advance...
Old   April 22, 2008, 09:37
Default Re: High resolution scheme???
Andrew
The high resolution scheme is described in the documentation. It is essentially a second order advection scheme. Upwind (first order) advection does not usually reproduce reality well, but its increased stability can help you arrive at better state for initial conditions to obtain convergence for a higher order advection scheme.
Best practice guidelines recommend using second-order advection wherever possible except in the case of turbulence models, where second-order advection schemes usually will not converge.
The upwind scheme may be ok for comparing the performance of 2 similar designs (to see if a change in a car fender results in less drag), but it probably won't accurately reproduce measured integral quantities (like pressure drops and drag force), let alone local flow properties.
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
high resolution scheme venkatesh4386@gmail.com CFX 5 April 20, 2014 23:37
[CFD-Post] High resolution scheme blend factor siw CFX 5 May 26, 2011 17:23
high resolution scheme az_f CFX 0 November 24, 2010 22:52
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
