April 21, 2008, 14:12 |
ICEM CFD Prism errors
Prism keeps failing with the output:
done smoothing marking triangles triangle xxx xxx xxx seems to be in the wrong family triangle xxx xxx xxx seems to be in the wrong family where xxx are numbers that I assume correspond to the nodes connected to the triangle. I've generated and regenerated meshes for this geometry (using the same meshing parameters and method) and the number of triangles in wrong families varies each time. On one of my meshes there is only 1 triangle labeled as being in the wrong family. How can I identify it and assign it to the correct family or otherwise get prism to run on the mesh? I tried adding nodes to a subset by element number, but only 1 of the numbers from the message is a valid node number. The mesh has no unconnected vertices. |
April 22, 2008, 10:00 |
Re: ICEM CFD Prism errors
Possibly resolved.
It appears prism won't run if you set the number of surface and volume smoothing steps to 0. I set them to 1 and it runs. |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
icem cfd ai environment 11.0, laptop keyboard problem, linux | pertupd | Hardware | 3 | October 3, 2011 08:27 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
How is ICEM CFD mesh file format? | Seth | CFX | 4 | March 2, 2008 17:22 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
