May 2, 2008, 07:17 |
prism mesh in 2D
hi guys!
does anybody know, how I can generate a prism layer in 2D? it works without problems in 3D, because you can pick a surface to set the layers on. in 2D though, there isn't anything like that... it also fails when I pick my spline to set the layers on. I hope someone can help me ... |
May 2, 2008, 07:50 |
Re: prism mesh in 2D
The easiest thing to do is use a 2D blocking with bunching, convert to a surface mesh, then extrude that.
May 2, 2008, 08:39 |
hmm ... did that, problem is though, my geometry is too compley to block everything.
gotta be automatic, somehow... |
May 2, 2008, 11:10 |
You can build your model in 3D - then delete all of the mesh but the surface in question - and extrude that. There is always a way in ICEM - but it's not always elegant.
May 2, 2008, 11:11 |
Also - if you have a QUAD license (for patch-based surface meshing) you can use that to mesh the surface and use 'number of layers' (I think) to build the 'prism' layers off the desired curve.
[ICEM] Creation of hexa dominant mesh and prism layer | gnuboard | ANSYS Meshing & Geometry | 7 | January 11, 2018 04:13 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 07:06 |
Prism with anisotropic trimmed mesh | fastwave | STAR-CCM+ | 1 | May 9, 2010 10:29 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
