March 17, 2010, 17:51 |
Negative Pressure?
Michael Petrarca
Rep Power: 17 |
I have a post open in the meshing/geometry section of the boards. I've finished everything, ran a steady state simulation at 60 mph, k-e turbulence, etc. When I looked at the pressure contour on the surface of the model, at first I thought everything was fine, until I noticed that the legend showed some parts with a negative pressure.
Is this an error that I can fix without too much of a headache? I realized that I need to add inflation layers to my mesh, but without those would a negative pressure occur? -Michael Petrarca |
March 18, 2010, 06:55 |
Rep Power: 143 |
The pressure is relative to your reference pressure. Assuming your reference pressure is 1 bar then you have pressure ranging from approx 99500Pa to 100500Pa absolute.
March 18, 2010, 14:49 |
#3 | |
Michael Petrarca
Rep Power: 17 |
Thank you for your reply. I thought that this was a representation of absolute pressure. Lesson learned . |
March 18, 2010, 16:47 |
Rep Power: 143 |
The absolute pressure is also available as a different variable.
August 11, 2011, 23:28 |
TAO JUN
Rep Power: 15 |
the absolute static pressure of your results will be positive.
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
seeking for help about a room with negative pressure | mengyue1 | FLUENT | 0 | November 26, 2009 06:40 |
High pressure in rhopSonicFoam results in negative pressure | shangzung | OpenFOAM | 0 | November 5, 2009 03:24 |
negative pressure in cfx | flar.t | CFX | 1 | December 18, 2006 23:20 |
negative pressure | mAx | FLUENT | 0 | January 25, 2006 14:31 |
