Catalogue error
I am currently doing conjugate heat transfer analysis with a mesh size of 4.3 million elements,while trying to run this model into parallel computing with 4 processors we are facing an error stating INCREASE THE CATOLOGUE SIZE .
Re: Catalogue error
Dear Sudhakar,
You should edit your definition file in the Solver. Solver - Edit definition file - (choose your def file) - flow - solver control -( when you are here you can choose the "edit" - add parameter) - in the pop up window you will see the "catalogue size multiplier") - you can type here for example 1.2 Best regards Bela |
