Inlet Profile with CFX-Pre
Old   June 10, 2008, 06:00
Default Inlet Profile with CFX-Pre
Fadi Ishak
Hello all,
Could someone help me out with this problem? I have a structured mesh and I would to introduce an inlet profile in the shape of a step function (on-off-on) to simulate the velocity flow behind in the wake region behind a turbine blade. Is this possible in cfx-pre? I know there is an option to set a simple inlet profile in cfx-pre but the profile I am creating will almost divide the inlet into three regions, if you will.
Thanks in advance for your help.
Old   June 10, 2008, 07:12
Default Re: Inlet Profile with CFX-Pre
Look in the reference manual under CEL. Use either the step function or a 1D interpolation function.
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
FSI- Pipe- uniform velocity profile inlet Absy Main CFD Forum 0 April 6, 2010 03:01
scalarField inlet profile BC potac OpenFOAM Pre-Processing 0 January 16, 2010 11:09
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
how to give sectional velocity profile at inlet? fkonias CFX 3 January 29, 2008 09:28
