Mey
Rep Power: 7 ![]() |
I would like to simulate warm air distribution in a car. I have a heat source that needs to be variable by changing the inside car temperature. This means that when I reach my target temperature in the car, the heat power should decrease. My problem is that I cannot write an expression at the point where my sensor is located. In fact, the expression I write has an error. Can you tell me how I should write a proper expression for this condition? condition: if Ttarget- Tsensor >0.5 K then Heat source power 10 kW if not Heat source power 5 kW . Variable --> Ttarget=21, Tsensor= Expression, Heat Source= Expression |
Rep Power: 145 ![]() ![]() ![]() ![]() |
It is a few simple CEL expressions:
Ttarget = 21[C] Tsensor = probe(T)@Location HeatSourcePower = if(Ttarget- Tsensor >0.5 C,10[kW],5[kW]) And set the heat source to HeatSourcePower Note that this expression cannot be used for a steady state run as it has no steady solution. It can only be used for transient runs.
Mey
Dear Glenn,
I hope you are fine. As you said, this model or case is not for steady-state conditions. However, the expression Tsensor = probe(T)@Location does not work. I defined a small volume and then, instead of a point, used the volume (Domain) and wrote the expression like minVal(Temperature)@SensorDomain. Then it worked without an expression error. When I have a misunderstanding or make a mistake somewhere, please let me know. best, |
If you want to debug the probe approach please post your CEL and/or output file. Also include any error it is reporting.
Display Modes | |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Outlet boundary condition in interFoam | Andrea_85 | OpenFOAM Running, Solving & CFD | 51 | July 20, 2017 13:31 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
