Drone Porpeller
Old   February 17, 2025, 09:29
Default Drone Porpeller
Madalin Dombrovschi
DombrovschiM is on a distinguished road
Hello everyone,
I am trying to analyze a drone propeller with CFX. But i have a problem, what inlet and outlet conditions should I use?
For INLET i used pressure with relative 0 Bar
Same for outlet, the domain is rotating with a given RPM, but the resulted force of the propeller is way to low ( compared with the experimental data of the propeller)
Do you have any idea?
P.S.: I don't wanna use velocity/mass flow inlet because I don't believe this is the way of doing this analysis.
Thank you
DombrovschiM is offline   Reply With Quote
Old   February 17, 2025, 17:35
What configuration are you trying to model? You set your boundary conditions to match the configuration you are trying to model.
I would guess that a drone is moving forward at some velocity, and that the propeller is reasonably open to the atmosphere (not in a duct or anything). If this is correct then I would use a velocity inlet and a pressure outlet. Why do you "believe" this is not correct?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
cfx, drone, propeller thrust
3d fan zone. Drone propeller sebayanez1204 FLUENT 0 July 5, 2023 21:48
Drone simulation Marax111 STAR-CCM+ 3 March 5, 2018 14:15
Drone Roter Simulation Procedure Anupsingh CFX 2 May 26, 2017 07:45
