Chen Rui
Rep Power: 3 ![]() |
Hello everyone,
I want to use CFX to simulate the case of non-equilibrium phase transition of turbine expander (water vapor of IAPWS IF97 can be successfully simulated), but I use the RGP file of methane as a fluid to import into CFX, and the solution will report errors. (When the fluid changes from water vapor to methane, the surface tension coefficient must be added,The reason for the error is precisely the surface tension coefficient:“SIGMA”) The boundary conditions are Pin=12MPa,Tin=299.15K,Pout=6.7MPa. Error reported as follows: +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | NAME_MOD: Error finding variable "SIGMA" within domain "R1". CCL | | is possibly invalid. | +--------------------------------------------------------------------+ I have tried many modifications but can not solve this problem, please help me! Thank you very much! |
#2 | |
Rep Power: 34 ![]() |
Did you setup the case using a homogeneous binary mixture? Methane-Vapor and Methane-Liquid
#3 | |
Chen Rui
PMIN_SUPERHEAT 2.5000000E+004 PMAX_SUPERHEAT 6.5000000E+007 TMIN_SUPERHEAT 1.5000000E+002 TMAX_SUPERHEAT 5.0000000E+002 TMIN_SATURATION 1.5000000E+002 TMAX_SATURATION 2.2000000E+002 SUPERCOOLING 0.0000000E+000 P_CRITICAL 4.5992000E+006 P_TRIPLE 1.1696000E+004 T_CRITICAL 1.9056400E+002 T_TRIPLE 9.0694100E+001 GAS_CONSTANT 5.1827050E+002 I used the RGP plugin to generate methane.rgp file for methane vapor and methane liquid, vapor and liquid are selected thermodynamic states "liquid" and "gas" inside the CFX-Pre materials. Homogeneous binary mixture are defined in terms of methane vapor and methane liquid. The initial condition is that the methane gas phase volume fraction is 1 and the methane liquid phase volume fraction is 0. The aim is to consider droplet formation during expansion. |
If you think every other detail of your setup is correct, I would replace the methane RGP files with the provided RGP for water/steam.
there should be no difference since the materials' properties are just numbers. If the use persists, you are missing something in the setup.
#5 | |
Chen Rui
Dear Opaque, If you wish, please provide a water/steam RGP file. I would appreciate it very much. I also check my Settings for any omissions or problems.Thanks a lot. |
They are part of the installation.
#7 | |
huicheng zhang
Rep Power: 2 ![]() |
#8 | |
Chen Rui
https://ansyshelp.ansys.com/public/a.../ljjhk225.html If you have any other questions, you can also discuss them together. Currently, the simulation can be successfully carried out based on the case, but when it comes to applying to our own boundary conditions, some errors will occur. Thank you! |
#9 | |
huicheng zhang
#10 |
Rep Power: 145 ![]() ![]() ![]() ![]() |
If you have a valid ANSYS support license the link should work. The information on the link is copyright to ANSYS so we cannot copy it to somewhere else.
Display Modes | |
Multiphase solvers and non-isothermal phase change | erlend_grotle | OpenFOAM | 1 | September 25, 2021 09:48 |
Need help regarding phase change models in ansys fluent | diggee | Fluent Multiphase | 0 | October 11, 2016 11:35 |
Change phase phenomena | Imane | FLUENT | 0 | May 4, 2016 15:56 |
Pressure Outlet for phase change simulation | dinesh | FLUENT | 0 | November 21, 2013 23:50 |
Solid/liquid phase change | fabian_roesler | OpenFOAM | 10 | December 24, 2012 06:37 |
