June 18, 2008, 08:03 |
autogenerate mesh files in workbench
How can I auto generate mesh files in workbench for several input files? I have a parameter in each file that is just varied a little bit. Cheers Kim
June 19, 2008, 01:56 |
Re: autogenerate mesh files in workbench
You can not generate mesh in workbench, since It is for geometry generation.
June 19, 2008, 13:53 |
Hi Kim,
It sounds like you are looking for design explorer (DX) - it is a separate tool you can use in workbench to alter mesh, geometry, etc and run sensitivity studies however you like. You need a different license for it, but it is quite inexpensive compared to the rest of the products and allows for automation of lots of CFD runs in a few clicks. Note: I have never used it for this, and frequently when I tell people they can do this I am told I am wrong, but I have confirmed that my support person does this all the time and uses DX with CFX inside workbench no problem. -Alex |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
