Write Solver Input File Error (File Path not recognized)
Old   March 21, 2025, 16:14
Default Write Solver Input File Error (File Path not recognized)
Yiquan is on a distinguished road
My Supervisor gave me a def. File, and I make some changes, like decreasing the outlet mass flow rate. After changing the boundary condition, I want to output the def. File for later cluster calculation using Write Solver Input File. Then the following error comes: "The file path /dss/t7new_geometry/fran_rr.def is not recognised for this platform.
I think the file path is Linux-Form, which is why, but how can I change this file path to Windows form?
Could someone help me?
Yiquan is offline   Reply With Quote
Old   March 22, 2025, 03:15
I assume you did the changes to the mass flow rate in CFX-Pre.
In CFX-Pre you should go to the execution options and set the file and path for the definition file to be written. In fact, I recommend you get rid of all the path and just put the file name you want. It will then write it in the current working directory regardless of which OS you are using.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 22, 2025, 04:55
Thanks! It really helps!
Old   March 22, 2025, 10:18
John Doie
JohnDoie is on a distinguished road
Thanks for the suggestion! I’ll try replacing the forward slashes with backslashes in the file path and see if that resolves the issue. I'll make sure to use double backslashes if needed. I appreciate the help, and I’ll update you on the result. It’s good to know the difference between path formats on Linux and Windows, so I’ll make sure the paths are correct for the system I’m using. Thanks again for your support! For more insights and a complete overview, feel free to check out the detailed information available at this link: https://mycompany.filemail.com/d/fdmcpoqiinyajyg
JohnDoie is offline   Reply With Quote
cfx pre
[openSmoke] LaminarSMOKE compilation error mdhfiz OpenFOAM Community Contributions 8 July 2, 2024 11:32
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
