[Sponsors] | |||||
Rep Power: 0 ![]() |
Hello.
I have the task of simulating the heating process of a single-stage turbine, that includes stator, rotor and a solid body of the rotor. The initial state of a solid body is a uniform temperature of 20°C. During first 10 seconds the rotational speed, pressure and temperature at the turbine inlet are increasing, and after that remain constant (high). I need to calculate about 600 seconds until the solid body reaches a steady temperature state. Is it possible to perform such a calculation using transient blade row model (with sector modeling approach) or it is necessary to perform a "true" transient calculation with full annulus of rows? |
Rep Power: 34 ![]() |
What is the exact goal of the simulation?
Unless you are looking for thermal wave interactions affecting phase lag concerning other variables, you can get away with a single passage per row and run a transient. How familiar are you with modeling rotor-stator interactions?
Dear Opaque, thank you for the answer.
The exact goal of the simulation is to simulate turbine heating from "cold" state during turbocharger start procedure. And a look for thermal wave interactions is not a goal of the simulation. My experience is mainly connected with steady turbomachinery simulations. As I thought, to run a transient calculation, the full circumference of the turbomachine is required, except in cases where pitch-change methods such as PT, TT or FT are used. And again, as I thought, the solution with these methods converges to a "steady-periodic" state, but I need to simulate transient process with, for example, turbine rotational velocity change in time, which makes process not "steady-periodic". But from your answer I see that I can get away with a single passage per row and just run a transient. This is a new information for me. |
| Tags |
| conjugate heat transfer, transient analisys, transient blade row, turbines |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 06:27 |
| Comparison of under-floor heating and radiator heating | Mountainbike | OpenFOAM Running, Solving & CFD | 1 | November 27, 2020 07:55 |
| 6dof for rotation of turbine: unable to fix the center | Havinh | Fluent UDF and Scheme Programming | 0 | August 5, 2015 06:35 |
| Air Flow Analysis around a Wind Turbine | NightHawkRaven | FLUENT | 4 | August 12, 2014 18:18 |
| Boundary condition setting regarding turbine simulation using CFX | Lacerlacer | CFX | 11 | March 12, 2012 10:32 |
