ploting a line or point data along with time
Like Tree3Likes
  • 2 Post By ghorrocks
  • 1 Post By Opaque
Old   April 18, 2025, 18:12
Default ploting a line or point data along with time
smhk is on a distinguished road
Hello everyone.After running the simulation in CFX . I have a line which I want to plot the velocity over it in every time step together. Is there any way to plot them or export the data over line as well as time steps?
A simpler case: plotting the velocity for a point over time.
Thank you.
smhk is offline   Reply With Quote
Old   April 19, 2025, 05:53
Do you want to show an animation of velocity vectors? Just draw the line, put a vectors object in using the line and use the animation tool to animate it over time.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   April 19, 2025, 15:56
No, I want to have the data over the line (velocity) at each time step together so I can take the time average of them (as an example). Not to export velocities for each time step to a spreadsheet software then take the time average of them
Old   April 19, 2025, 22:05
Have you looked at the transient statistics in CFX? You might be able the calculate what you want with that so you do not need to do it.
I do not understand your question, you seem to say you want to export the data so you can calculate stuff but then you say that is not what you want to do.
So I am going to guess that you want to export data - that is easy with file/export in CFD-Post. You can select your line as the object to export, and you can do it for each time step you have a results file for.
Old   April 21, 2025, 16:26
I thank you for the time you spend to answer my question ghorrocks.
I want to plot data (Velocity or Pressure) of a point over time.
Old   April 21, 2025, 18:02
In that case you can define a monitor point in the output tab of CFX-Pre, and then as the simulation progresses the value of that monitor point can be shown in Solver Manager. The monitor point will be output every time step regardless of what transient results files you save.
Opaque and smhk like this.
Old   April 21, 2025, 18:39
Opaque will become famous soon enough
and you can compute a few transient statistics on those values as well.
smhk likes this.
Opaque is offline   Reply With Quote
Old   April 27, 2025, 08:55
Thank you.
plot over time, plot over time steps
Issues With Exporting From GMSH rberdon Mesh Generation & Pre-Processing 0 February 11, 2021 11:11
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 00:37
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
