June 27, 2008, 04:36 |
[CFX Post] : Wireframe, ...
Hi, I have a geometry divided in 7 domains. My simulation converged well in CFX-Solver.
When I want to load the .res file in CFX-Post, I get the following : - If I choose to load all the domains, I get nothing... No wireframe, .... I can't plot streamlines, ... When I want to use "Turbo", only the first four domains are available. There is no sign of the last 3 ones. - If I choose to load only the first four domains then it worked well... Any ideas why I get such a behaviour. What could be wrong with the last three domains ? Regards, Hervé |
June 27, 2008, 12:33 |
Re: [CFX Post] : Wireframe, ...
Dear pal,
In Turbo mode you can only visualize those components which are pertaining to Turbomachinery blades. For example in a Francis Turbine, you can only visualize guidevanes & runner. Its not possible to the see casing & draft tube. Also you can only initialize blade components, after initializing you will be seeing a fan like logo at those components which the turbo can identify & the rest will be in red colour. I hope I have understood your problem correctly. Regards, Amit Roghs |
Gambit-how to create a wireframe face from so many edges? | gholamghar | ANSYS | 0 | February 18, 2011 08:22 |
[OpenFOAM] wireframe as solid | rcastilla | ParaView | 3 | April 3, 2009 19:09 |
Gambit: Face from wireframe problem | smillerhh | FLUENT | 0 | September 29, 2006 03:54 |
mismatch between the wireframe and surface data | Richard | CFX | 0 | March 9, 2006 01:15 |
creating real face from a wireframe | Nicklas | FLUENT | 2 | October 11, 2004 09:05 |
