Custom material properties for a copper from table
Like Tree1Likes
  • 1 Post By ghorrocks
Old   May 23, 2025, 11:35
Default Custom material properties for a copper from table
nrbrt is on a distinguished road
I would like to simulate the behavior of a copper heat exchanger at cryogenic temperatures.
In such environments, the material properties change significantly. A common approach is to define tables with values for each Kelvin, specifying the corresponding:
Temperature Specific Heat Capacity Thermal Conductivity Electrical conductivity
Could someone provide an example of a properly
.CCL
file for this purpose? I can fill with the values, just I dont know the correct syntax. Thank you!
nrbrt is offline   Reply With Quote
Old   May 24, 2025, 06:31
If the properties are a function of temperature only then it is easy to do. In CFX-Pre use a 1-D interpolation function. They are quite simple to set up so you should work it out quickly. Also the CFX-Pre documentation can help.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   May 26, 2025, 13:11
In the meantime I found a way. I put it here in case. This is for copper with RRR=10 and it contains: Resistivity, Thermal conductivity, Specific heat vs. temperature . You can have more points for higher resolution.
Old   May 26, 2025, 19:03
It is much easier if you do it as a 1D interpolation function.
Opaque likes this.
Fluent UDF to interpolate material properties from Temp and Pressure dependent table lablan Fluent UDF and Scheme Programming 14 June 21, 2021 22:56
Custom Material Properties Table Generation PabloXX37 CFX 4 January 31, 2020 11:56
How to set (real) material properties? JimVoul OpenFOAM 0 November 26, 2019 10:28
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
Material Properties table? (function of two variables) evcelica CFX 2 October 1, 2012 19:36
