simple pipe flow question
Old   June 29, 2008, 18:08
Default simple pipe flow question
arkur
Hi
I have run a simple pipe flow with periodic boundaries using RANS model. When I checked the velocity in post it was around 0.4 m/s in the middle of pipe. However, according to the paper that I am using, the bulk velocity is 2m/s. Is there a difference between bulk and mean velocity? Thank you
Old   July 11, 2008, 16:32
Default Re: simple pipe flow question
aNdReS17
The laminar steady velocity distribution in a circular pipe is parabolic in shape. The mean and bulk velocity are the same thing. It is the average velocity. The max. velocity occurs in the middle of the pipe. Thus the max. velocity appears to be 0.4 m/s (from your statement). The mean velocity is always smaller than the max velocity, thus the mean (bulk) velocity CANNOT be 2 m/s.
Question regarding Fluent's Turbulent Pipe Flow Problem clueless Main CFD Forum 0 May 15, 2009 03:59
Question regarding Fluent's Turbulent Pipe Flow Problem clueless FLUENT 0 May 15, 2009 03:33
simple pipe flow question arkur Main CFD Forum 0 June 29, 2008 18:07
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
