How to visualize velocity components
Old   October 2, 2025, 06:02
Default How to visualize velocity components
Kei Tanaka
Kendas is on a distinguished road
I define a local coordinate system and don't know how to calculate the velocity components of the defined local coordinate system.
Kendas is offline   Reply With Quote
Old   October 3, 2025, 00:14
What do you want to do with the velocities in your coord system? For most things on CFD-Post the coord system does not matter as the velocity vector looks the same regardless of the coord system. So for most visualisations of velocities inside CFD-Post the coord system does not matter.
If you are exporting it then there is an option to define what coord system to use.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 3, 2025, 00:35
Kei Tanaka
As shown in the attached image, there are three outlet, and I want to obtain the velocity components in the circumferential, radial, and axial directions for each outlet.
Old   October 3, 2025, 00:54
Do you want a single representative velocity vector at each outlet? ..... if so, then get the velocity components in the absolute frame from the average velocity over the patch, then do your own transform into your coord system
Or do you want the whole velocity distribution over the outlet patches? .... if so, it depends on what you want to do with it.
Old   October 3, 2025, 03:41
Kei Tanaka
Yes, I want a single representative velocity vector at each outlet.
However, I am not sure how to transform the results into my coord system, even though I have been reading the manual.
Old   October 3, 2025, 04:38
You do not do it in CFX or CFD-Post. This is just a few equations and you do it yourself.
This page has an excellent description of coordinate transforms: https://stackoverflow.com/questions/...tem-to-another
Old   October 3, 2025, 04:58
Kei Tanaka
Thank you. I'll try it myself.
Velocity components Mohamed Abohelwa CFX 0 September 5, 2022 07:20
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
Specify velocity components at outlet jtwilson FLUENT 1 August 28, 2015 12:58
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY everest20 FLUENT 1 July 13, 2015 09:35
Velocity cylindrical components from OpenFOAM aerospain OpenFOAM 2 October 17, 2012 08:09
